Hi!
I hope you could help me with the problem I've been having with this HMI.
Usually I use the Instruction-based alarms (ALMD) in the program of my PLC Controller (ControlLogix 5580) to be able to send Alarm Messages to my View Designer Panel View. However, on this new HMI I'm getting the alarm trigger on the Panelview (I get the prompt on the Alarm Summary, and get the Alarm TAG of the ALMD Instruction associated with the alarm), but for some reason the Alarm Message is on blank. It´s the same for all the alarms on the controller.
I checked again and the "Message" parameter of the ALMD is configurated, and even test just typing "a" as an Alarm Message to see if it was that the string was too long, but even with that the message didn't show up. Can you help me understand what I'm doing wrong?
I experienced a similar issue. I was seeing the alarm message on the HMI Alarm Summary, but not in the Alarm History.  It was resolved after I re-downloaded the View designer project to the HMI
