Glen7829 Posted November 11, 2022 Report Posted November 11, 2022 I have a test station to test MR-J2S Servo drivers, I am looking for something unique in the drivers to be able to save data about that test. First thought was the SN, but i am not seeing any way to pull serial number from the driver. Only found it on the side of driver and really don't want people having to type it in , cause usually they type in the wrong numbers. Does anyone know of a way to get the serial number out of the driver? or at least where it could be found? Or any other unique identifier in these drivers?
glavanov Posted November 16, 2022 Report Posted November 16, 2022 Configuration software MR Configurator (MRZJW3-SETUP151E) should give you the serial nmber and software number of the amp. See section 14.1.2 from here: https://dl.mitsubishielectric.com/dl/fa/document/manual/servo/sh030006/sh030006j.pdf Also: https://dl.mitsubishielectric.com/dl/fa/document/manual/servo/ib0300058/ib0300058c.pdf
Glen7829 Posted November 16, 2022 Author Report Posted November 16, 2022 I did connect MR Configurator 151E to one, but i only seen software version. No serial number. I have also looked threw both of those PDFs and nothing about serial number. I am able to communicate to it just cant find a way to ask it ... whats your SN#
glavanov Posted November 16, 2022 Report Posted November 16, 2022 You are right. I haven't used MR Configurator in years. It only shows the software version... my bad! MRC2 for JE/J3/J4... series shows the serial number but the good old J2 series is not in the list.
