Hi. what i've gathered, i need an EDS-file for the siemens s7-1200-system to be able to specify an ethernet connection in sysmac from the omron plc side to connect to the siemens ethernet/ip server.
Anyone know where or how to get an EDS file for the siemens plc so i can import it into EIPprofiles in sysmac?
Look like it is available if you are registered on their support website:
https://support.industry.siemens.com/cs/document/109782315/ethernet-ip-adapter-connecting-third-party-control-systems-to-simatic-s7-controllers-via-ethernet-ip?dti=0&lc=en-HN
Alternatively you could try the Omron Generic EDS file available on this site which works with most devices.
