I have two HMIs connected to one PLC.
The HMIs are identical.
I'm downloading the same program to both and the only problem I have is that once it's downloaded to one I have to disconnect the network cable to download to the other. Is there a way to force TIA Portal to search for a target?
What is the best way to utilise two identical HMIs on one PLC, with the least work/pain?
Ok, thanks. I've got the different IP addresses.
The connections are identical but it works. I think that has to be changed on all the tags?  What difference does the connection actual make out of interest. If I could read the packets going back and forth over ethernet would they be different?
