akbar_torkashwand Posted March 16, 2023 Report Posted March 16, 2023 hello every body. I want to upload program from E100 HMI Beijer. I have " E - Designer " software and CAB5 programing cable. I tried with USB to serial cable and windose XP virtual.But I couldn't connect . can anybody help me?
Gambit Posted March 16, 2023 Report Posted March 16, 2023 Make sure the CAB5 is in connected the right way. only one side is for the PC !!
akbar_torkashwand Posted March 25, 2023 Author Report Posted March 25, 2023 yes. CAB5 is connected in right way.but I couldn't upload program.
Gambit Posted March 29, 2023 Report Posted March 29, 2023 The usb => R232 creates a virtal serial port. Are you sure you are using the right port number ? Also I would try another converter and check if you are using the latest driver for it
pturmel Posted March 29, 2023 Report Posted March 29, 2023 If the USB->Serial converter doesn't have an FTDI chipset, expect problems.
akbar_torkashwand Posted March 29, 2023 Author Report Posted March 29, 2023 3 hours ago, pturmel said: If the USB->Serial converter doesn't have an FTDI chipset, expect problems. how can I found my USB to SERIAL cable have " FTDI chipset "?
pturmel Posted March 29, 2023 Report Posted March 29, 2023 You have to look at the specs for the product. Other common chipset are from "Prolific" and have "PLxxxx" part numbers. These do not behave like real COM ports as well as the FTDI-based devices. I'm sure there are other chipsets. YMMV.
Goghie Posted March 30, 2023 Report Posted March 30, 2023 With Beijer, often is problem with driver. If you have different driver installed on HMI than with E-Designer it often makes problem.
Ron_S Posted March 30, 2023 Report Posted March 30, 2023 You start at the beginning. Check your pc has a usb to serial port showing - and what com port number it is. If you do, open a blank E100 project and go to Transfer. select Recieve and set the Com port to the same number.
akbar_torkashwand Posted March 31, 2023 Author Report Posted March 31, 2023 On 3/30/2023 at 0:25 AM, Goran Vuckovic said: With Beijer, often is problem with driver. If you have different driver installed on HMI than with E-Designer it often makes problem. Yes .I chose correct driver in empty program.
akbar_torkashwand Posted March 31, 2023 Author Report Posted March 31, 2023 13 hours ago, Ron_S said: You start at the beginning. Check your pc has a usb to serial port showing - and what com port number it is. If you do, open a blank E100 project and go to Transfer. select Recieve and set the Com port to the same number. I have made it many time. but result is same. at the end. I decided to provide real serial port with real windows XP and test. 13 hours ago, Ron_S said:
akbar_torkashwand Posted April 4, 2023 Author Report Posted April 4, 2023 On 3/31/2023 at 11:53 PM, akbar_torkashwand said: I have made it many time. but result is same. at the end. I decided to provide real serial port with real windows XP and test. On 3/31/2023 at 11:53 PM, akbar_torkashwand said: I have made it many time. but result is same. at the end. I decided to provide real serial port with real windows XP and test. Now I can connect with E100 with real windows xp and real serial port.but E100 is V4.03 and my software has only V6.0. so I couldn't upload program. I have E-Designer v7.50. where can I download older version?
Gambit Posted April 4, 2023 Report Posted April 4, 2023 If you disable check terminal version in the tranfser settings you should be able to do an upload of the pogram.
akbar_torkashwand Posted April 5, 2023 Author Report Posted April 5, 2023 If I disable check terminal version in the tranfser settings and upload program with higher version . is it possible to download on it in the future. ?
Gambit Posted April 5, 2023 Report Posted April 5, 2023 Yes by checking that same button or you can update the firmware if the panel is not to old. But it would be better if the firmware matches between software and hardware. you shuld be able to install the old software aswell
Ron_S Posted April 6, 2023 Report Posted April 6, 2023 I usually let sleeping dogs lie with version and firmware updates. If they were working perfectly before I came - they'll be the same versions when I have gone. Probably because I once 'bricked an E300 doing an unnecessary upgrade.
akbar_torkashwand Posted April 7, 2023 Author Report Posted April 7, 2023 Hello Ron_S. I don't understand what you say. please tell me more
Ron_S Posted April 8, 2023 Report Posted April 8, 2023 I mean you will get warnings that the versions do not match. Ignore it and upload anyway.
