Parity1 Posted April 17, 2023 Report Posted April 17, 2023 Hello. Im building my own recipe tool and was wondering if i can somehow get the min/max values shown in recipe ingredients list to use in vbnet script? Im displaying the recipes and their ingredient names/values in listboxes and based on the selected index making changes to the actual recipe. Im using EditVariable-function with custom keypads to make changes to recipes and they allow min/max values. So i would like to access the min/max values of a selected recipe to show in my custom keypad. Instruction reference manual does not seem to mention those, only recipe names and ingredient name/value. GetRecipeIngredients- mentions it just stores the ingredient value as obj. They are however used in the recipeViewer tool when selecting a recipe so there must be some way to access them right? Quote
sergeFR Posted April 18, 2023 Report Posted April 18, 2023 hi in the page calling the numerickeypad , i made a script : Sub Appel_Clavier If Modification_Valeur = "Fréquence moteur soupape" Then Sauvegarde_ancienne_valeur = Frequence_soupape EditVariable("Frequence_soupape", , , ,"10" ,"75.01" , ,"NUMERICKEYPAD", ,"Group0") then i have min( 10) /max (75.01) for each value. Quote
Parity1 Posted April 18, 2023 Author Report Posted April 18, 2023 Thank you for the reply. Sorry if i was not clear on what i was trying to accomplish. Im looking to replace those min/max values in keypad settings with a variable that gets the min/max values from recipes. In editVariable it would look like: EditVariable("strValue",,"False","True",min_var,max_var,,keyboard_type,,keyb_grp) So for example when user selects the servo2_position to edit from the list the min/max needs to be different than for servo1_position. Of course i can make a separate list with all of the min/max values and choose correct min/max for each instance but it would be lovely if i could somehow access these straight from recipe. Quote
