Hi on a NA5 15W101 V1.11 in sysmac studio:
I cannot figure out how to set up a Move Horizontal/Vertical Expressions within Animations tab inside any object properties.
For example my epression would be something like Move(Check_Condition_Variable, 100, Horizontal(?)) but as an expression.
Edited by Artz
Hi
You can map variables(global, type integer) directly from you plc to to horizontal and vertical expression- fields on move animation and do your condition check on plc side.
Or you can make a variable in HMI, create global event for condition, and add SetVariable as actionUntitled.thumb.png.25e9c63e8e3868e314a5c
Or you could make Subroutine doing the same.
  • Like 1
I wanted to write the exrpession here since sysmac already provides an easy way to do so.
Edited by Artz
The fields are expecting a pixel position. You can do the math in code or in the PLC then use an Integer tag.
Maybe I don't understand your question...
How dumb of me... it was just solved with a single line If... statement
If(variable=True,330,20). Srry that this was just a beginner in VB thing.
