smarius76 Posted April 21, 2023 Report Posted April 21, 2023 Hi I try to make a communication between CJ2M (with SCU 32), as master, and two EasyLogic PM2200, as slaves, through a modbus RTU communication. I use function block specified in this library https://www.myomron.com/index.php?article=1245&action=kb (I Use MRTU_SCU_Master sample) but no response fom the slave. On Modbus Error code (from function block) appear code 8303 hex. What I am doing wrong. Can somebody help me? Thank you Quote
mike_cheesehead Posted April 24, 2023 Report Posted April 24, 2023 myOMRON Europe: Services & Support Did you configure like this? what are your adresses? Quote
smarius76 Posted April 24, 2023 Author Report Posted April 24, 2023 (edited) 43 minutes ago, mike_cheesehead said: myOMRON Europe: Services & Support Did you configure like this? what are your adresses? I use CJ2M with SCU32, Modbus RTU, in the sample is CP1L Modbus TCP. I use function block MRTU_SCU_Master.zip from this https://www.myomron.com/index.php?action=kb&article=1245 Edited April 24, 2023 by smarius76 Quote
mike_cheesehead Posted April 24, 2023 Report Posted April 24, 2023 Easy to use Modbus RTU Master for CP1L CP1H CJ1 CJ2 CS1 - PLC Sample Code - Forums.MrPLC.com sorry its serial modbus oke the link above gives you a more indept explanation of how to set up Modbus including hardware Quote
