vnstudy Posted April 18, 2005 Report Posted April 18, 2005 I am a student and I am learning about PLC. I have a problem with GE Fanuc. It's not work corectly so I need a software to communicate with this one to find out the errors. Please help me if you have this software. Thank you very much. Quote
Steve Bailey Posted April 18, 2005 Report Posted April 18, 2005 You will need to indicate which model PLC you have before you can get any meaningful assistance. If you contact a local distributor of GE Fanuc products, they might be willing to make the programming software available to you. If the PLC belongs to your school, then the school should have the proper software. Quote
vnstudy Posted April 19, 2005 Author Report Posted April 19, 2005 The PLC's model is GE Fanuc 90-30 . Someone told me that I need Versa Pro software . I am in Viet Nam and there is not a local distributor of GE Fanuc products in my coutry. It would be greatly appreciated if anyone has one. Thanks and best regards Quote
Steve Bailey Posted April 19, 2005 Report Posted April 19, 2005 VersaPro is one software package that can be used to program a 90-30. Logicmaster is another. Logicmaster is a DOS application. VersaPro is a Windows application. The most current package is called Proficy Machine Edition Logic Developer PLC. If you are trying to maintain the PLC on an existing machine, then you need the programming software with which the program was originally written. You should have a copy of the program files available to you. Without it, you won't have any rung comments or address names. There is (or was) a demo version of Logicmaster software available on the GE Fanuc website. Quote
