I'm afraid I don't fully understand your question.
You might be asking if there is a way to run the program with all outputs disabled. The answer to that is, yes. You have the option to run the program with outputs enabled or disabled. You can also force individual outputs on or off. Forcing is a two-step process. First, you force the output. That action freezes it in its current state, regardless of what the program may tell it to be. After forcing you can turn it to whichever state you desire. Forcing can only be done to discrete (on/off) outputs. You can't force an analog output to a value different than what the program commands.
