Trying to check the control ( RSTI-EP  EPXCPE210 ) with Proficy
I have the same results with project created from empty and created by template.
The control is an RSTI-EP  EPXCPE210
4 EP-1214 INPUT CARDS
1 EP-3264 AI CARD
1 EP-3804 TC CARD
1 EP-5111 HSC CARD
1 EP-2614 OUTPUT CARD
Another happening is the IP I configure for lan 1 ends up on port 3. I don't know what port 1 IP is.
The fault table
PacsAnalyzer 4.6
Report for PLC at 10.10.0.10,  CPU: PACSystems EPXCPE210, FW: 10.30
Short target name: PRISM10
Full target name: PRISM101
Host  PC   Date/Time: 04-27-2023 14:38:39
Controller Date/Time: 04-27-2023 14:38:39
Old  Controller Time: 01-01-2001 00:00:20
Controller State: Cpu Stop Faulted
Redundancy State: Simplex
############################  MODULE INFO for RACK 0  #########################
SLOT  MODEL             PRIMARY FW      BOOT FW         HW       SERIAL             DATE               CATALOG
 0    EPXCPE210         10.30 [EJTT]                    1.03     R867447                               EPXCPE210-AAAA
 0.1  IC695EFM001       10.30 [EJTT]                             R867447                               EPXCPE210-AAAA
 1    EP-1214           0.03.80                         1.10.00  AW1E24PC7300746
 2    EP-1214           0.00.03                         1.10.00  AW1E24PC7300708
 3    EP-1214           0.00.00                         1.10.00  AW1E24PC7300732
 4    EP-1214           0.03.80                         1.10.00  AW1C24PC7300590
 5    EP-3264           1.02.00                         1.30.00  AW8O24PC7302525    20220824
 6    EP-3804           1.00.13                         1.20.00  AW9G24PC7300128    20220916
 7    EP-5111           1.00.13                         0.91.00  AT3180PC7300020
 8    EP-2614           1.00.13                         1.20.00  AW6E42PC7301488
 9    ---
10    ---
11    ---
12    ---
13    ---
14    ---
15    ---
16    ---
17    ---
18    ---
19    ---
20    ---
21    ---
22    ---
23    ---
24    ---
25    ---
26    ---
27    ---
28    ---
29    ---
30    ---
31    ---
32    ---
33    ---
34    ---
35    ---
36    ---
37    ---
38    ---
39    ---
40    ---
41    ---
42    ---
43    ---
44    ---
45    ---
46    ---
47    ---
48    ---
49    ---
50    ---
51    ---
52    ---
53    ---
54    ---
55    ---
56    ---
57    ---
58    ---
59    ---
60    ---
61    ---
62    ---
63    ---
64    ---
#############################  PLC FAULT TABLE  ###############################
Last cleared: 01-01-2001 00:00:00
Displaying 64 of 103 faults (39 overflowed), in time descending order.
64. Location: 0.0   Date/Time: 01-01-2001 00:00:18.050
    Group:16  MOD_OTHR_SOFTWR - Option module software failure
    Error Code:402  LAN system software fault; resuming
    Action:2   Task Num:6   Event Type:08H  PLC Backplane Driver
    Extra Data: 08 00 17 00 19 00 49 00 04 00 63 81 08 00 02 00 00 00 00 00 00 00 00 00
         ASCII:  .  .  .  .  .  .  I  .  .  .  c  .  .  .  .  .  .  .  .  .  .  .  .  .
63. Location: 0.0   Date/Time: 01-01-2001 00:00:00.347
    Group:140  INFO_CPU_SOFTWR - CPU software event
    Error Code:3  Error detected by initialization or powerup routine
    Action:1   Task Num:3
    Extra Data: 04 6a 01 3b 80 1e 00 8c 8c 00 1e 80 3b 01 00 00 00 00 00 00 00 00 00 00
         ASCII:  .  j  .  ;  .  .  .  .  .  .  .  .  ;  .  .  .  .  .  .  .  .  .  .  .
62. Location: 0.0   Date/Time: 01-01-2001 00:00:15.669
    Extra Data: 08 00 17 00 19 00 8f 00 04 00 63 81 08 00 02 00 00 00 00 00 00 00 00 00
         ASCII:  .  .  .  .  .  .  .  .  .  .  c  .  .  .  .  .  .  .  .  .  .  .  .  .
61. Location: 0.0   Date/Time: 01-01-2001 00:00:00.347
    Action:1   Task Num:3
60. Location: 0.0   Date/Time: 01-01-2001 00:00:00.345
    Action:1   Task Num:3
59. Location: 0.0   Date/Time: 04-27-2023 13:49:14.069
    Extra Data: 08 00 17 00 19 00 58 00 04 00 63 81 08 00 02 00 00 00 00 00 00 00 00 00
         ASCII:  .  .  .  .  .  .  X  .  .  .  c  .  .  .  .  .  .  .  .  .  .  .  .  .
58. Location: 0.0   Date/Time: 01-01-2001 00:00:12.968
    Extra Data: 08 00 17 00 19 00 b9 00 04 00 63 81 08 00 02 00 00 00 00 00 00 00 00 00
57. Location: 0.0   Date/Time: 01-01-2001 00:00:00.349
    Action:1   Task Num:3
56. Location: 0.0   Date/Time: 01-01-2001 00:00:17.355
    Extra Data: 08 00 17 00 19 00 3b 00 04 00 63 81 08 00 02 00 00 00 00 00 00 00 00 00
         ASCII:  .  .  .  .  .  .  ;  .  .  .  c  .  .  .  .  .  .  .  .  .  .  .  .  .
55. Location: 0.0   Date/Time: 01-01-2001 00:00:00.341
    Action:1   Task Num:3
54. Location: 0.0   Date/Time: 01-01-2001 00:00:00.342
    Action:1   Task Num:3
53. Location: 0.0   Date/Time: 01-01-2001 00:00:17.748
    Extra Data: 08 00 17 00 19 00 bd 00 04 00 63 81 08 00 02 00 00 00 00 00 00 00 00 00
52. Location: 0.9   Date/Time: 01-01-2001 00:00:02.273
    Group:11  CNFG_MIS_MTCH - System configuration mismatch
    Error Code:1  Module does not match configuration
    Action:2   Task Num:9
    Extra Data: 04 f3 03 75 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
         ASCII:  .  .  .  u  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .
51. Location: 0.0   Date/Time: 01-01-2001 00:00:00.341
    Action:1   Task Num:3
50. Location: 0.9   Date/Time: 01-01-2001 00:00:02.283
    Action:2   Task Num:9
49. Location: 0.0   Date/Time: 01-01-2001 00:00:00.351
    Action:1   Task Num:3
48. Location: 0.9   Date/Time: 01-01-2001 00:00:02.267
    Action:2   Task Num:9
47. Location: 0.0   Date/Time: 01-01-2001 00:00:00.339
    Action:1   Task Num:3
46. Location: 0.0   Date/Time: 01-01-2001 00:37:42.822
    Extra Data: 08 00 17 00 19 00 7b 00 04 00 63 81 08 00 02 00 00 00 00 00 00 00 00 00
         ASCII:  .  .  .  .  .  .  {  .  .  .  c  .  .  .  .  .  .  .  .  .  .  .  .  .
45. Location: 0.9   Date/Time: 01-01-2001 00:37:20.269
    Action:2   Task Num:9
44. Location: 0.9   Date/Time: 01-01-2001 00:33:33.548
    Action:2   Task Num:9
43. Location: 0.0   Date/Time: 01-01-2001 00:16:13.540
    Group:14  MOD_NF_HARDWR - Module non-fatal hardware error
    Error Code:463  Ethernet Link Restored on Port 3
    Action:2   Task Num:6
    Extra Data: 20 00 09 00 02 00 00 00 01 02 58 00 00 00 00 00 00 00 00 00 00 00 00 00
         ASCII:     .  .  .  .  .  .  .  .  .  X  .  .  .  .  .  .  .  .  .  .  .  .  .
42. Location: 0.0   Date/Time: 01-01-2001 00:16:04.832
    Error Code:462  Ethernet Link Lost on Port 3
    Action:2   Task Num:6
    Extra Data: 20 00 08 00 02 00 00 00 01 02 cf 00 00 00 00 00 00 00 00 00 00 00 00 00
         ASCII:     .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .
41. Location: 0.0   Date/Time: 01-01-2001 00:13:16.788
    Error Code:458  Ethernet Link Lost on Port 1
    Action:2   Task Num:6
    Extra Data: 20 00 04 00 00 00 00 00 01 02 cf 00 00 00 00 00 00 00 00 00 00 00 00 00
40. Location: 0.0   Date/Time: 01-01-2001 00:12:31.408
    Group:130  BAD_USER_RAM - Corrupted user ram detected on power-up
    Error Code:7  Battery failure detected while PLC off; user memory not preserved
    Action:2   Task Num:0
    Extra Data: 00 14 03 75 80 2e 00 06 0c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
39. Location: 0.0   Date/Time: 01-01-2001 00:09:43.165
    Action:2   Task Num:6
38. Location: 0.0   Date/Time: 01-01-2001 00:08:39.265
    Action:2   Task Num:6   Event Type:1bH  SRTP Server
    Extra Data: 1b 00 0b 00 15 00 16 00 03 05 a2 a3 a8 00 3e 63 00 0a 0a db e2 00 00 00
         ASCII:  .  .  .  .  .  .  .  .  .  .  .  .  .  .  >  c  .  .  .  .  .  .  .  .
37. Location: 0.9   Date/Time: 01-01-2001 00:08:38.135
    Action:2   Task Num:9
36. Location: 0.0   Date/Time: 01-01-2001 00:00:03.174
    Error Code:413  ACD Subsystem Interface IP Fault
    Action:2   Task Num:6
    Extra Data: 38 00 37 00 01 00 00 01 e7 00 01 81 2a 00 30 00 00 00 00 00 00 00 00 00
         ASCII:  8  .  7  .  .  .  .  .  .  .  .  .  *  .  0  .  .  .  .  .  .  .  .  .
35. Location: 0.0   Date/Time: 01-01-2001 00:00:02.376
    Action:2   Task Num:0
34. Location: 0.0   Date/Time: 01-01-2001 00:00:00.374
    Action:1   Task Num:3
33. Location: 0.0   Date/Time: 01-01-2001 00:00:03.173
    Action:2   Task Num:6
---------------------------------  Overflow boundary  ---------------------------------
32. Location: 0.0   Date/Time: 01-01-2001 02:24:28.908
    Action:2   Task Num:6
31. Location: 0.0   Date/Time: 01-01-2001 02:24:28.404
    Action:2   Task Num:0
30. Location: 0.0   Date/Time: 01-01-2001 02:04:14.199
    Error Code:461  Ethernet Link Restored on Port 2
    Action:2   Task Num:6
    Extra Data: 20 00 07 00 01 00 00 00 01 02 58 00 00 00 00 00 00 00 00 00 00 00 00 00
29. Location: 0.0   Date/Time: 01-01-2001 02:04:09.620
    Error Code:460  Ethernet Link Lost on Port 2
    Action:2   Task Num:6
    Extra Data: 20 00 06 00 01 00 00 00 01 02 cf 00 00 00 00 00 00 00 00 00 00 00 00 00
28. Location: 0.0   Date/Time: 01-01-2001 02:03:21.809
    Action:2   Task Num:6
27. Location: 0.0   Date/Time: 01-01-2001 01:47:41.199
    Action:2   Task Num:6
26. Location: 0.0   Date/Time: 01-01-2001 01:47:39.536
    Extra Data: 1b 00 0b 00 15 00 16 00 03 05 a2 a3 a8 00 3e 0a 00 a8 c0 9d f8 00 00 00
         ASCII:  .  .  .  .  .  .  .  .  .  .  .  .  .  .  >  .  .  .  .  .  .  .  .  .
25. Location: 0.9   Date/Time: 01-01-2001 01:47:38.405
    Action:2   Task Num:9
24. Location: 0.8   Date/Time: 01-01-2001 01:47:38.405
    Action:2   Task Num:9
23. Location: 0.0   Date/Time: 01-01-2001 01:17:29.389
    Action:2   Task Num:6
22. Location: 0.0   Date/Time: 01-01-2001 01:17:15.891
    Action:2   Task Num:6
21. Location: 0.0   Date/Time: 01-01-2001 01:10:59.478
    Action:2   Task Num:6
20. Location: 0.0   Date/Time: 01-01-2001 01:10:56.381
    Action:2   Task Num:6
19. Location: 0.0   Date/Time: 01-01-2001 00:32:47.324
    Error Code:459  Ethernet Link Restored on Port 1
    Action:2   Task Num:6
    Extra Data: 20 00 05 00 00 00 00 00 01 02 58 00 00 00 00 00 00 00 00 00 00 00 00 00
18. Location: 0.0   Date/Time: 01-01-2001 00:32:39.376
    Action:2   Task Num:6
17. Location: 0.0   Date/Time: 01-01-2001 00:16:00.733
    Action:2   Task Num:6
16. Location: 0.0   Date/Time: 01-01-2001 00:14:21.970
    Action:2   Task Num:6
15. Location: 0.0   Date/Time: 01-01-2001 00:14:04.427
    Action:2   Task Num:6
14. Location: 0.0   Date/Time: 01-01-2001 00:00:02.376
    Action:2   Task Num:0
13. Location: 0.0   Date/Time: 01-01-2001 00:00:00.372
    Action:1   Task Num:3
12. Location: 0.0   Date/Time: 01-01-2001 02:36:16.851
    Action:2   Task Num:6
11. Location: 0.0   Date/Time: 01-01-2001 00:00:02.375
    Action:2   Task Num:0
10. Location: 0.0   Date/Time: 01-01-2001 00:00:00.372
    Action:1   Task Num:3
 9. Location: 0.0   Date/Time: 01-01-2001 00:00:02.371
    Action:2   Task Num:0
 8. Location: 0.0   Date/Time: 01-01-2001 00:00:00.371
    Action:1   Task Num:3
 7. Location: 0.0   Date/Time: 01-01-2001 00:00:02.377
    Action:2   Task Num:0
 6. Location: 0.0   Date/Time: 01-01-2001 00:00:00.373
    Action:1   Task Num:3
 5. Location: 0.0   Date/Time: 01-01-2001 00:21:50.370
    Action:2   Task Num:0
 4. Location: 0.0   Date/Time: 01-01-2001 00:00:02.372
    Action:2   Task Num:0
 3. Location: 0.0   Date/Time: 01-01-2001 00:00:00.369
    Action:1   Task Num:3
 2. Location: 0.0   Date/Time: 01-01-2001 00:00:02.645
    Error Code:1  Normal powerdown was bypassed; cache memory was not saved
    Action:2   Task Num:0
    Extra Data: 00 14 03 75 80 2e 00 06 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 1. Location: 0.0   Date/Time: 01-01-2001 00:00:00.631
    Action:1   Task Num:3
##############################  IO FAULT TABLE  ###############################
Last cleared: 04-27-2023 13:45:22
Displaying 0 of 0 faults (0 overflowed), in time descending order.
############################ FORCES IN CONTROLLER ############################
No forces detected.
############################ ETM Analysis for 10.10.0.10 ###############################
node
EPXCPE210-AAAA Embedded Ethernet Interface
Copyright (c) 2003-2022.  All rights reserved.
Version 10.30 (EJTT) TCP/IP
Version 1.2.4.REL Loader
Running Image: Primary
Version 1.3 Hardware
01.00.00 FPGA
Version NA BIOS
Serial No = R867447    Date Code =
<<< Ethernet LAN 1 >>>
IP Address = 10.10.0.10         Subnet Mask = 255.255.0.0
Gateway = 0.0.0.0
MAC Address = <<000991B543AB>>
<<< SNTP Not Configured >>>
Source of Soft Switches: PLC Configuration
Source of IP Address:    Configuration
Advanced User Parameters are modified; use "parm" command to display
<<< Ethernet LAN 2 >>>
IP Address = 192.168.0.10       Subnet Mask = 255.255.0.0
Gateway = 0.0.0.0
MAC Address = <<000991B543AC>>
Apr 27, 2023  14:38:40.2 (+0:00)
Date/time initialized from PLC CPU
Unit up time: 24 seconds
log
<<< Extended Exception Log >>>
EPXCPE210-AAAA Embedded Ethernet Interface version 10.30 (EJTT)
27-Apr-2023 14:38:40.3 (+0:00)
Log initialized using valid RAM information
Log last cleared 31-Dec-2000 23:59:59.9 (+0:00)                                               Remote IP Addr:Port
  Date         Time                    Event Count  Entry 2 through Entry 6       SCode        or Producer ID:Exchg    Local IP Addr:Port
  31-Dec-2000  23:59:59.8 (+0:00)       1H    1H   0000H 0000H 0000H 0000H 0000H
  01-Jan-2001  00:04:46.0 (+0:00)      20H    1H   0008H 0002H 0000H 0001H 02cfH
  01-Jan-2001  00:00:17.3 (+0:00)       8H    1H   0017H 0019H 003bH 0004H 0063H 81080002H
  01-Jan-2001  01:11:11.0 (+0:00)      20H    1H   0008H 0002H 0000H 0001H 02cfH
  01-Jan-2001  00:00:12.9 (+0:00)       8H    1H   0017H 0019H 00b9H 0004H 0063H 81080002H
  01-Jan-2001  00:13:16.7 (+0:00)      20H    0H   0008H 0002H 0000H 0001H 02cfH
  27-Apr-2023  13:48:54.8 (+0:00)       1H    1H   0000H 0000H 0000H 0000H 0000H
  27-Apr-2023  13:49:14.0 (+0:00)       8H    1H   0017H 0019H 0058H 0004H 0063H 81080002H
  31-Dec-2000  23:59:59.8 (+0:00)       1H    2H   0000H 0000H 0000H 0000H 0000H
  27-Apr-2023  14:25:09.0 (+0:00)      20H    1H   0008H 0002H 0000H 0001H 02cfH
  01-Jan-2001  00:00:00.0 (+0:00)       1H    1H   0000H 0000H 0000H 0000H 0000H
  01-Jan-2001  00:00:15.6 (+0:00)       8H    1H   0017H 0019H 008fH 0004H 0063H 81080002H
->01-Jan-2001  00:00:18.0 (+0:00)       8H    1H   0017H 0019H 0049H 0004H 0063H 81080002H
sosw
<<< Soft Switch Data - Ethernet LAN 1 >>>
IP Address           = 10.10.0.10         (TCP/IP values from Soft Switches)
Gateway              = 0.0.0.0
<<< Soft Switch Data - Ethernet LAN 2 >>>
IP Address           = 192.168.0.10       (TCP/IP values from Soft Switches)
Gateway              = 0.0.0.0
stat b
<<< Memory Status >>>   27-Apr-2023 14:38:40.0 (+0:00)
Free Bytes in Partition       : 1177088
Free Blocks in Partition      : 39
Maximum free block size       : 949520
Allocated Bytes in Partition  : 271450832
Allocated Blocks in Partition : 27201
<<< IP Memory Pool Status >>>   27-Apr-2023 14:38:40.0 (+0:00)
________________
MBUFS POOL TABLE
____________________________________________________________________
type      number
FREE      15360
DATA      0
HEADER    0
SOCKET    0
PCB       0
RTABLE    0
HTABLE    0
ATABLE    0
SONAME    0
ZOMBIE    0
SOOPTS    0
FTABLE    0
RIGHTS    0
IFADDR    0
CONTROL   0
OOBDATA   0
IPMOPTS   0
IPMADDR   0
IFMADDR   0
MRTABLE   0
TOTAL     15360
number of mbufs: 15360
number of times failed to find space: 0
number of times waited for space: 0
number of times drained protocols for space: 0
__________________
CLUSTER POOL TABLE
size      clusters   free       usage
64        6144       6144       0
64        6144       6144       0
64        6144       6144       0
128       3072       3072       0
256       1536       1536       0
512       1536       1536       0
1024      1536       1536       0
2048      1536       1536       0
<<< EMAC Driver Memory Pool Status >>>   27-Apr-2023 14:38:40.0 (+0:00)
    LAN 1 Ethernet Adapter
________________
MBUFS POOL TABLE
type      number
FREE      4415
DATA      193
HEADER    0
SOCKET    0
PCB       0
RTABLE    0
HTABLE    0
ATABLE    0
SONAME    0
ZOMBIE    0
SOOPTS    0
FTABLE    0
RIGHTS    0
IFADDR    0
CONTROL   0
OOBDATA   0
IPMOPTS   0
IPMADDR   0
IFMADDR   0
MRTABLE   0
TOTAL     4608
number of mbufs: 4608
__________________
CLUSTER POOL TABLE
1600      4608       4415       557
    LAN 2 Ethernet Adapter
________________
MBUFS POOL TABLE
type      number
FREE      2751
DATA      321
HEADER    0
SOCKET    0
PCB       0
RTABLE    0
HTABLE    0
ATABLE    0
SONAME    0
ZOMBIE    0
SOOPTS    0
FTABLE    0
RIGHTS    0
IFADDR    0
CONTROL   0
OOBDATA   0
IPMOPTS   0
IPMADDR   0
IFMADDR   0
MRTABLE   0
TOTAL     3072
number of mbufs: 3072
__________________
CLUSTER POOL TABLE
1600      3072       2751       321
stat v
<<< SRTP Server Status >>>   27-Apr-2023 14:38:40.0 (+0:00)
Endpoint   Task        State  Num Requests  Client IP Address:Port   Timeout
     0*      25  ESTABLISHED            41        10.10.0.99:59670    16 sec
 Total connections used by SRTP = 1
 Asterisk (*) indicates privileged SRTP Server connection.
 Sharp (#) indicates CPU Slot1-to-Slot0 translation enabled.
 CPU Slot1-to-Slot0 redirection allowed.
tally v
<<< SRTP Server Tallies >>>   27-Apr-2023 14:38:40.0 (+0:00)
InPDU   =0000009eH  OutPDU  =0000009eH  BadPDU  =00000000H  InConRq =00000002H
OutConRp=00000002H  InDatRq =00000095H  OutDatRp=00000097H  InUncRq =00000000H
OutUncRq=00000000H  InErrRq =00000000H  OutErrRq=00000000H  InDisRq =00000001H
OutDisRq=00000000H  InSesRq =00000002H  InDstRq =00000002H  OutDstRp=00000002H
InPrvRq =00000002H  OutPrvRp=00000002H  InIToRq =00000001H  OutIToRp=00000001H
OpenTO  =00000000H  InactTO =00000000H
stat c
<<< BPD Status >>>   27-Apr-2023 14:38:40.0 (+0:00)
BPD state: Normal operation
CPU state: Stopped (03H)
CPU Ethernet daughterboard at Node ID = 00 00 01 a0
LIS = 9003H
User                Xfers      Xfers      BlkXfer      BlkXfer     COMMREQs
 ID     Status      to CPU    from CPU    size         Address     discarded
   0        Ready         bH         bH          0H          0H          0H
   6        Ready         1H         0H          0H          0H          0H
  13        Ready         0H         0H          0H          0H          0H
  23        Ready         0H         0H          0H          0H          0H
  24        Ready         1H         1H          0H          0H          0H
  25        Ready        26H        26H          0H          0H          0H
  98        Ready         0H         0H          0H          0H          0H
 125        Ready         0H         0H          0H          0H          0H
 127        Ready         0H         0H          0H          0H          0H
Comm_Req storm detection is enabled
Comm_Req storm(s) since startup = 0
Current Comm_Req rate = 0/sec
<<< Shared Memory Status >>>   27-Apr-2023 14:38:40.0 (+0:00)
Shared memory startup complete (07H)
I/F version: 1.03
Shared memory heap status:
   Heap memory size (bytes)             = 2097152 (200000H)
   Total heap available size (bytes)    = 2091008 (1fe800H)
   Largest available allocation (bytes) = 1048576 (100000H)
   Total allocations in use (bytes)     = 6144 (1800H)
tally c
<<< PLC Driver Tallies >>>   27-Apr-2023 14:38:40.0 (+0:00)
UsrReq  =000000a2H  UsrRsp  =000000a2H  UsrMsg  =00000003H  UnsolMsg=00000002H
PlcReq  =00000003H  PlcRsp  =00000003H  Cmrq    =00000000H  CmrqDscd=00000000H
PlcSweep=00000000H  PktToPlc=000000a8H  PktFmPlc=000000a7H  PktUnreg=00000000H
BsyRetry=00000000H  BpdAbort=00000000H  PlcTmout=00000000H  UsrTmout=00000000H
BadMbQlf=00000000H  CmrqStrm=00000000H
<<< Shared Memory Interface Tallies >>>   27-Apr-2023 14:38:40.0 (+0:00)
IntRcv  =000000a7H  IntSent =00000002H  CmdRSRst=00000000H  CmdRHMsg=00000000H
CmdRLMsg=000000a6H  CmdRTest=00000001H  CmdRUnsp=00000000H  CmdSHRst=00000000H
CmdSSRst=00000000H  CmdSHMsg=00000001H  CmdSLMsg=00000000H  CmdSTest=00000001H
IoIScans=00000000H  IoInSet =00000002H  IoTimSet=00000772H  SmhAlloc=00000074H
SmhFree =00000095H  SmhDblFr=00000000H  MtMbSend=000000a8H  MtMbRsnd=00000000H
MtSndAbt=00000000H  MtMbRcv =000000a8H
stat g
<<< EGD Status >>>   27-Apr-2023 14:38:41.0 (+0:00)
No exchanges are currently configured!
Number of exchanges (current + added by RMS) = 0
Number of producer tasks = 0
tally g
<<< EGD Tallies >>>   27-Apr-2023 14:38:41.0 (+0:00)
EstConRq=00000000H  EstConRp=00000000H  ConnRdy =00000000H  EnabOut =00000000H
DisabOut=00000000H  TermRq  =00000000H  TermRp  =00000000H  DataRx  =00000000H
DataTx  =00000000H  RefrErr =00000000H  UnRecID =00000000H  SigErr  =00000000H
UnscnC  =00000000H  Stale   =00000000H  EstMCnRq=00000000H  MrkTrmRq=00000000H
ActvDel =00000000H  ActvAdd =00000000H  Cleanup =00000000H  RmsCmdRp=00000000H
SuspDel =00000000H  SuspAdd =00000000H  MissdCEx=00000000H
<<< EGD COMMAND Tallies >>>   27-Apr-2023 14:38:41.0 (+0:00)
RdRqRcv =00000000H  RdRpSnt =00000000H  WrRqRcv =00000000H  WrRpSnt =00000000H
RdRqSnt =00000000H  RdRpRcv =00000000H  WrRqSnt =00000000H  WrRpRcv =00000000H
CfRqRcv =00000000H  CfRpSnt =00000000H  SmRqRcv =00000000H  SmRpSnt =00000000H
CpRqRcv =00000000H  CpRpSnt =00000000H  StRqRcv =00000000H  StRpSnt =00000000H
AlinErr =00000000H  ExchErr =00000000H  SigErr  =00000000H  LenErr  =00000000H
OffErr  =00000000H  TooLong =00000000H  PduErrm =00000000H  RejRcv  =00000000H
RejSnt  =00000000H  Timeout =00000000H
stat l
<<< Network Interface Status >>>   27-Apr-2023 14:38:41.0 (+0:00)
LAN1 NI state = UP
  Data rate 1000Mbps, Full duplex
LAN2 NI state = DOWN
tally l
<<< Network Interface Tallies >>>   27-Apr-2023 14:38:41.0 (+0:00)
RcvUniPk=00000148H  RcvMcPkt=0000002dH  DiscPkt =00000000H  RcvError=00000000H
UnkProto=00000000H  SndUniPk=00000211H  SndMcPkt=00000001H  SndError=00000000H
SndDscd =00000000H
<<< Detailed Network Interface Tallies >>>   27-Apr-2023 14:38:41.0 (+0:00)
RxCRCEr =00000000H  RxAlign =00000000H  RxSymErr=00000000H  RxError =00000000H
RxMisPkt=00000000H  RxLenErr=00000000H  RxXon   =00000000H  RxXoff  =00000000H
RxFcUnSp=00000000H  RxNoBuf =00000000H  RxRntPkt=00000000H  RxFrag  =00000000H
RxGiant =00000000H  RxJabber=00000000H  RxMgt   =00000000H  RxMgtDrp=00000000H
TxSngCol=00000000H  TxExsCol=00000000H  TxMulCol=00000000H  TxLatCol=00000000H
TxColl  =00000000H  TxExsDef=00000000H  TxLosCar=00000000H  TxSeqErr=00000000H
TxCarErr=00000000H  TxXon   =00000000H  TxXoff  =00000000H  TxMgmt  =00000000H
TxTcpSeg=00000000H  TxTcpFal=00000000H
<<< Ethernet Port Offline Tallies >>>   27-Apr-2023 14:38:41.0 (+0:00)
EthP1Off=00000000H  EthP2Off=00000000H  EthP3Off=00000000H
stat w
<<< TCP Status >>>   27-Apr-2023 14:38:41.0 (+0:00)
Min Retran T/O = 1000, Max Retran T/O = 60000, Retran Alg = 4,
Max Conn = 2048, Current Conn = 1
<<< netstat Info >>>   27-Apr-2023 14:38:41.0 (+0:00)
INET sockets
Prot  Recv-Q Send-Q Local Address                 Foreign Address               State
TCP   0      0      0.0.0.0.2300                  0.0.0.0.*                     LISTEN
TCP   0      0      127.0.0.1.58257               127.0.0.1.49793               TIME_WAIT
TCP   0      0      0.0.0.0.443                   0.0.0.0.*                     LISTEN
TCP   0      0      0.0.0.0.80                    0.0.0.0.*                     LISTEN
TCP   0      0      0.0.0.0.502                   0.0.0.0.*                     LISTEN
TCP   0      0      0.0.0.0.18245                 0.0.0.0.*                     LISTEN
TCP   0      0      10.10.0.10.18245              10.10.0.99.59670              ESTABLISHED
UDP   0      0      127.0.0.1.20005               127.0.0.1.20004
UDP   0      0      0.0.0.0.161                   0.0.0.0.*
UDP   0      0      0.0.0.0.18245                 0.0.0.0.*
UDP   0      0      10.10.0.10.62429              0.0.0.0.*
UDP   0      0      192.168.0.10.62321            0.0.0.0.*
UDP   0      0      0.0.0.0.18246                 0.0.0.0.*
INET6 sockets
tally w
<<< TCP Tallies >>>   27-Apr-2023 14:38:41.0 (+0:00)
ActOpens=00000001H  PasOpens=00000003H  AtmptFai=00000000H  EstabRes=00000000H
CurEstab=00000001H  InSegs  =00000149H  OutSegs =000001f0H  RtranSeg=00000000H
InErrs  =00000000H  SndRsts =00000000H
stat h
<<< SRTP Client Status >>>   27-Apr-2023 14:38:41.0 (+0:00)
                                                 Status  Transfers
Ch  Type     Server Address    State             Code    Completed
tally h
<<< SRTP Channels Tallies >>>   27-Apr-2023 14:38:41.0 (+0:00)
InPDU   =00000000H  OutPDU  =00000000H  BadPDU  =00000000H  OutConRq=00000000H
InConRp =00000000H  OutDstRq=00000000H  InDstRp =00000000H  OutSesRq=00000000H
InSesRp =00000000H  OutDatRq=00000000H  InDatRp =00000000H  OutErrRq=00000000H
InErrRq =00000000H  OutUncRq=00000000H  OutDisRq=00000000H  InDisRq =00000000H
InCmd   =00000000H  BadCmd  =00000000H  OutBpdEr=00000000H  InBpdEr =00000000H
stat s
Invalid task: s
tally s
Invalid task: s
stat o
<<< Modbus TCP Server Status >>>   27-Apr-2023 14:38:42.0 (+0:00)
No active connections
tally o
<<< Modbus TCP Server Tallies >>>   27-Apr-2023 14:38:42.0 (+0:00)
InPDU   =00000000H  OutPDU  =00000000H  BadPDU  =00000000H  InConRq =00000000H
OutConRp=00000000H  InDatRq =00000000H  OutDatRp=00000000H  OutErrRp=00000000H
InDisRq =00000000H  OutDisRq=00000000H  FC01    =00000000H  FC02    =00000000H
FC03    =00000000H  FC04    =00000000H  FC05    =00000000H  FC06    =00000000H
FC07    =00000000H  FC08    =00000000H  FC15    =00000000H  FC16    =00000000H
FC20    =00000000H  FC21    =00000000H  FC22    =00000000H  FC23    =00000000H
stat m
<<< Modbus TCP Client Status >>>   27-Apr-2023 14:38:42.0 (+0:00)
                                                 Status  Transfers
tally m
<<< Modbus Channels Tallies >>>   27-Apr-2023 14:38:42.0 (+0:00)
InPDU   =00000000H  OutPDU  =00000000H  BadPDU  =00000000H  OutDatRq=00000000H
InDatRp =00000000H  InErrRp =00000000H  OutDisRq=00000000H  InDisRq =00000000H
InCmd   =00000000H  BadCmd  =00000000H  InOpen  =00000000H  InClose =00000000H
InRdData=00000000H  InWrData=00000000H  InRdWr  =00000000H  InMaskWr=00000000H
OutBpdEr=00000000H  InBpdEr =00000000H  OutConRq=00000000H  InConRp =00000000H
chist
<<< Channel History >>>   27-Apr-2023 14:38:42.0 (+0:00)
================ CHANNEL HISTORY - Channel: 01 ================
                EVENT DESCRIPTION                  DATA1       DATA2
================ CHANNEL HISTORY - Channel: 02 ================
================ CHANNEL HISTORY - Channel: 03 ================
================ CHANNEL HISTORY - Channel: 04 ================
================ CHANNEL HISTORY - Channel: 05 ================
================ CHANNEL HISTORY - Channel: 06 ================
================ CHANNEL HISTORY - Channel: 07 ================
================ CHANNEL HISTORY - Channel: 08 ================
================ CHANNEL HISTORY - Channel: 09 ================
================ CHANNEL HISTORY - Channel: 10 ================
================ CHANNEL HISTORY - Channel: 11 ================
================ CHANNEL HISTORY - Channel: 12 ================
================ CHANNEL HISTORY - Channel: 13 ================
================ CHANNEL HISTORY - Channel: 14 ================
================ CHANNEL HISTORY - Channel: 15 ================
================ CHANNEL HISTORY - Channel: 16 ================
tally p
<<< OS Events Tallies >>>   27-Apr-2023 14:38:42.0 (+0:00)
OpenEvnt=00000013H  ClosEvnt=00000002H  ClosEcb =00000000H  ClosTmr =00000000H
CnclEvnt=00000003H  RxEvnt  =00000a79H  SndEvnt =00000013H  SndEvAft=00000003H
SndEvEvr=00000004H  RxEvTmot=00000001H  EvAftSnt=00000000H  EvEvrSnt=0000087cH
EvCncled=00000000H
fatalinfo diag
No core dump info present
fatalinfo rtos
<<< Fatal RTOS Fault Information >>>
Fatal Error data is empty
Watchdog Timeout data is empty
RDN Trace Data:
BP log messages:
***AUDIT TRAIL LOG***
            TIMESTAMP                               EVENT DESCRIPTION          DATA1     DATA2     DATA3     DATA4
01-Jan-01 02:56:13.052  HWC/Logic Source: Memory not Preserved              00000000  00000000  00000000  00000000
01-Jan-01 02:56:13.374  PLC Power Up Mode: Stop Mode                        00000000  00000000  00000000  00000000
01-Jan-01 04:18:47.000  Device Power Up                                     00000000  00000000  00000000  00000000
01-Jan-01 04:18:47.360  PLC Mode: Run IO Disabled - Switch                  00000000  00000000  00000000  00000000
01-Jan-01 04:18:49.051  HWC/Logic Source: Memory not Preserved              00000000  00000000  00000000  00000000
01-Jan-01 04:18:49.372  PLC Power Up Mode: Stop Mode                        00000000  00000000  00000000  00000000
01-Jan-01 04:23:59.000  Device Power Up                                     00000000  00000000  00000000  00000000
01-Jan-01 04:23:59.364  PLC Mode: Run IO Disabled - Switch                  00000000  00000000  00000000  00000000
01-Jan-01 04:24:01.053  HWC/Logic Source: Memory not Preserved              00000000  00000000  00000000  00000000
01-Jan-01 04:24:01.375  PLC Power Up Mode: Stop Mode                        00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.000  Device Power Up                                     00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.363  PLC Mode: Run IO Disabled - Switch                  00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.054  HWC/Logic Source: Memory not Preserved              00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.372  PLC Power Up Mode: Stop Mode                        00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.055  HWC/Logic Source: Memory not Preserved              00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.376  PLC Power Up Mode: Stop Mode                        00000000  00000000  00000000  00000000
01-Jan-01 00:08:08.272  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
01-Jan-01 00:08:37.440  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:08:37.481  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
01-Jan-01 00:08:38.178  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
01-Jan-01 00:08:39.269  PME Programmer Mode Disconnect                      00000000  00000000  00000000  00000000
01-Jan-01 00:12:29.000  Device Power Up                                     00000000  00000000  00000000  00000000
01-Jan-01 00:12:29.395  PLC Mode: Run IO Disabled - Switch                  00000000  00000000  00000000  00000000
01-Jan-01 00:12:31.085  HWC/Logic Source: Memory not Preserved              00000000  00000000  00000000  00000000
01-Jan-01 00:12:31.408  PLC Power Up Mode: Stop Mode                        00000000  00000000  00000000  00000000
01-Jan-01 00:14:03.235  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
01-Jan-01 00:14:18.320  PME Programmer Mode Disconnect                      00000000  00000000  00000000  00000000
01-Jan-01 00:33:02.848  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
01-Jan-01 00:33:32.850  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:33:32.891  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
01-Jan-01 00:33:33.591  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
01-Jan-01 00:33:38.505  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
01-Jan-01 00:33:41.685  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
01-Jan-01 00:37:18.000  Device Power Up                                     00000000  00000000  00000000  00000000
01-Jan-01 00:37:18.328  PLC Mode: Run IO Disabled - Switch                  00000000  00000000  00000000  00000000
01-Jan-01 00:37:20.116  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:41:09.747  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.328  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.116  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:06:43.638  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
01-Jan-01 00:07:13.767  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:07:13.778  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:07:13.876  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
01-Jan-01 00:07:14.545  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
01-Jan-01 00:07:19.593  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
01-Jan-01 00:07:22.895  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
01-Jan-01 00:08:24.423  PME Programmer Mode Disconnect                      00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.340  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.127  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:07:22.081  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
01-Jan-01 00:08:14.089  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:08:14.100  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:08:14.198  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
01-Jan-01 00:08:14.838  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
01-Jan-01 00:08:20.040  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
01-Jan-01 00:08:23.148  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.330  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.118  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.331  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.123  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:02:26.890  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
01-Jan-01 00:02:43.199  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:02:43.210  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 00:02:43.308  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
01-Jan-01 00:02:43.990  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
01-Jan-01 00:02:48.853  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
01-Jan-01 00:02:51.570  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.113  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 01:09:28.048  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
01-Jan-01 01:10:31.363  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 01:10:31.375  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
01-Jan-01 01:10:31.472  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
01-Jan-01 01:10:32.089  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
01-Jan-01 01:10:36.911  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
01-Jan-01 01:10:39.637  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.338  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.121  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:02:17.689  PME User Event: Set Time of Day                     00000000  00000000  00000000  00000000
27-Apr-23 13:42:31.003  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
27-Apr-23 13:45:22.536  PME User Event: Clear IO Fault Table                00000000  00000000  00000000  00000000
27-Apr-23 13:48:55.000  Device Power Up                                     00000000  00000000  00000000  00000000
27-Apr-23 13:48:55.331  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
27-Apr-23 13:48:57.113  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
27-Apr-23 13:52:28.965  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
27-Apr-23 13:52:49.889  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
27-Apr-23 13:52:49.901  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
27-Apr-23 13:52:49.998  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
27-Apr-23 13:52:50.638  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
27-Apr-23 13:52:55.429  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
27-Apr-23 13:52:58.472  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
27-Apr-23 13:53:48.640  PME Programmer Mode Disconnect                      00000000  00000000  00000000  00000000
27-Apr-23 13:54:35.000  Device Power Up                                     00000000  00000000  00000000  00000000
27-Apr-23 13:54:35.332  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
27-Apr-23 13:54:37.114  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.334  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:22.502  PME User Event: Set Time of Day                     00000000  00000000  00000000  00000000
27-Apr-23 14:23:53.361  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
27-Apr-23 14:24:20.566  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
27-Apr-23 14:24:20.578  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
27-Apr-23 14:24:20.675  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
27-Apr-23 14:24:27.850  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
27-Apr-23 14:24:32.642  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
27-Apr-23 14:24:35.309  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
01-Jan-01 00:00:00.336  PLC Mode: Stop IO Disabled - Switch                 00000000  00000000  00000000  00000000
01-Jan-01 00:00:47.310  PME User Event: Set Time of Day                     00000000  00000000  00000000  00000000
27-Apr-23 14:33:41.975  PME Programmer Mode Connect                         00000000  00000000  00000000  00000000
27-Apr-23 14:34:28.488  PME User Event: Clear Initial/forced Values         00000000  00000000  00000000  00000000
27-Apr-23 14:34:28.595  PME User Event: Download to RAM Start               00000000  00000000  00000000  00000000
27-Apr-23 14:34:29.196  PME User Event: Download to RAM End                 00000000  00000000  00000000  00000000
27-Apr-23 14:34:34.020  PME User Event: Download to Flash Start             00000000  00000000  00000000  00000000
27-Apr-23 14:34:36.746  PME User Event: Download to Flash End               00000000  00000000  00000000  00000000
01-Jan-01 00:00:02.120  HWC/Logic Source: Flash                             00000000  00000000  00000000  00000000
01-Jan-01 00:00:20.032  PME User Event: Set Time of Day                     00000000  00000000  00000000  00000000
*** END OF AUDIT TRAIL LOG ***
I forgot to mention
#CFG-MM OFF
#ANY-FLT ON
#SY-FLT ON
#SY-PRES ON
#SBUS-ER OFF
Thank you for your time,
John
PacLog.txt
