PrecisionPLC Posted May 12, 2023 Report Posted May 12, 2023 Hi I am looking to move data on a part once it has been scanned at a station. All I need to move is the 2D matrix Code and time stamp. I have moved the code and time stamp into a bufferArray I am just unsure as to how to send it to the company computer. I am using Tia portal V15.1 If anyone would be able to assist me
SKA AB Posted June 14, 2023 Report Posted June 14, 2023 On 5/12/2023 at 2:12 PM, PrecisionPLC said: Hi I am looking to move data on a part once it has been scanned at a station. All I need to move is the 2D matrix Code and time stamp. I have moved the code and time stamp into a bufferArray I am just unsure as to how to send it to the company computer. I am using Tia portal V15.1 If anyone would be able to assist me How is the office computer connected to the plc? What PLC model are you using? You can perhaps use OPC-UA and read that from a software, or use S7NetPlus in C# and make a program pull the data where to you need it, as an example.
