getting two NX/NJ plc to communicate through CIP datalink, i can check  _EIP_TargetNodeErr[<IP node address>] and _EIP_RegTargetSta[<IP node address>] for communication problems. However this does not work when the datalink is done through CJ areas. I can get around it in program, but I would better like using an internal variable like the ones above. So far I didn't found anything in the documentation, are such flags existing and available as system variables?
Thanks
No system variables exist for communication that isn't cyclic and managed by the system itself. FINS, Modbus, MQTT, and Socket Services all fall in this category.
