clearthefog Posted May 29, 2023 Report Posted May 29, 2023 Hi In Zeliosoft FBD programming, is there a way to insert or redirect a line to place a function along an existing wire? Or do you have to clear the wire, and then reattach the wire origin to the new function input, and the new function output to where the wire terminated before (assuming you can remember?) Quote
