Artz Posted June 1, 2023 Report Posted June 1, 2023 Hi Did you had the necessity to generate an event everytime an item from a Recipe Viewer control is selected? If so, how did you solve the lack of an event like that directly from the recipe viewer? Quote
JYG Posted July 31, 2023 Report Posted July 31, 2023 I don't understand your problem. Can you explain details please? I'm using "RecipeViewer" and use a button to enable or disable a recipe. On enable, I use "WriteRecipeToController". Quote
