Hi everyone,
I am working with CIF41, when I change IP address to 192.168.250.10 it is still working ( I can connect PLC) but the Err lamp on CIF41 blinking. I cannot clear it until I change it to initial IP address.
Could you help me to clear the Err lamp?
Thank you.
When changing the IP address are you also changing the FINS node address to 10? If you have the conversion method set to automatic address generation and the FINS node address does not match the unit an error will occur.
  • Like 1
