Bill B Posted July 14, 2023 Report Posted July 14, 2023 Thank you for letting me join the form, this is my first post. I am currently changing to a new laptop and am unable to connect to our NJ PLC via ethernet with hub connection. I have installed CX-One and Sysmac Studio on the new laptop. Windows 10 We have a network of 40 CP1H PLC's ,1 CJ2M PLC, 1 NJ301 PLC and Multiple NS HMI's. I am able to connect with everything except the NJ PLC, so this tell me my network adapter and cables are all working. Also I can still connect with the old laptop. It passes the communications test and can be seen via communications middleware browser but will not go online. I spoke with Omron support and they thought maybe a fire wall. Our IT department has checked and they say nothing is being blocked. I uninstalled Sysmac Studio and reinstalled (using windows uninstall not an Omron remover) I am at a loss as my old laptop is on its last leg so do not want to be stuck. I have attached some screen shots. Hoping someone will have some ideas. Thank You
Crossbow Posted July 14, 2023 Report Posted July 14, 2023 Is the IP address on your laptop set in the 192.168.250.x range like the PLCs? Are you certain the IP address on the new laptop is not the same as another existing device?
Bill B Posted July 14, 2023 Author Report Posted July 14, 2023 Thank you for the rely Crossbow. Yes my Laptop is set to 192.168.250.129. and nothing else has that address. And I can connect to all the Cx-one PLC's on the same network the new laptop does not have an ethernet card so I am using an USB to Ethernet adapter, I thought that was maybe causing an issue so I tried it on my old laptop and it connected fine to the NJ. I do have XP mode installed in Hyper-V which has a virtual switch but that is the same setup I had on the old laptop.
Marc-André Posted August 9, 2024 Report Posted August 9, 2024 Has a solution been found to this issue? Im having the same problem, new laptop and cant connect to the plc, i did the communication test and it says test ok but when i try going online, it says a communication error occured My co-workers can connect to the plc so its comming from the computer but i have no clue what to search for now.
photovoltaic Posted August 11, 2024 Report Posted August 11, 2024 On 8/9/2024 at 3:32 PM, Marc-André said: Has a solution been found to this issue? Im having the same problem, new laptop and cant connect to the plc, i did the communication test and it says test ok but when i try going online, it says a communication error occured My co-workers can connect to the plc so its comming from the computer but i have no clue what to search for now. What version is the PLC and what version is Sysmac? This can occur when an older version of Sysmac tries to connect to a newer PLC.
CİHAN Posted August 14, 2024 Report Posted August 14, 2024 Update the Network Configurator Application that comes in the sysmac studio package and your problem will be solved.
