khoi Posted July 31, 2023 Report Posted July 31, 2023 Hi everyone, I cannot connect to my CP1H-XA-40DT-D via CP1W-CIF01 and CIF11. Could you tell me to check if these 2 cards still working or not? Thank you. Khoi Quote
IO_Rack Posted July 31, 2023 Report Posted July 31, 2023 Check the DIP switch settings according to the manual. Are you using both Option Ports? Certain combinations won't work, if I remember correctly. Quote
