How would I go about adding an alarm when a recipe is selected it will set that alarm off but also say which recipe was selected in the process when looking at the alarm viewer.
What I do is adding a button "Enable" and "Disable" beside the RecipeViewer in a dialog box.
You can select the recipe in the RecipeViewer and push the button "Enable" to confirm the selection.
Your "Enable" button must have a event calling subroutine like this :
Sub EventEnable
	RecipeEnabled = True
	WriteRecipeToController(RecipeViewerSelector.SelectedTemplate, RecipeViewerSelector.SelectedRecipe)
End Sub
Sub EventDisable
	RecipeEnabled = False
End Sub
