Krr Posted August 7, 2023 Report Posted August 7, 2023 (edited) Hi! I am using cMT-SVR-100, and i need to get the UserName to my PLC. I have difficulty getting the UserName-Register: PLW-10754 from the PLC (OMRON NX1P2). In the documentation is written register LW-10754 should do the same thing like PLW-10754, but it doesn’t. The approach i found on internet is to use a macros, but PLW-10754 doesn’t support macros. Please help. Any help will be appreciated. Thank You in advance Edited August 7, 2023 by Krr
Jolly Posted July 9 Report Posted July 9 You should try the Data Transfer (Window) object. You can transfer PLW-10754 to other registers, or directly to the PLC (by external trigger or by time). Data Transfer (Global) object does not have access to the register PLW just LW, so do not use it.
