Olly_J Posted August 16, 2023 Report Posted August 16, 2023 Hi, Does anyone know where to get EDS files for GX Works3 ? I can't open a file that I need to access because it has an "Unsupported Module". The module is 007ER-1FL2-T, it shows up on the Mitsubishi website but I cannot see any links to EDS files or any software related to this module. Cheers, Olly
FRANK RUIZ Posted August 18, 2023 Report Posted August 18, 2023 i had a god but i cannot find it. i can find others, but not for that product, i would suggest you contact your local Mitsi rep, or drop them an email. probably is because is not made by them, and is quite new or something...
Crossbow Posted August 21, 2023 Report Posted August 21, 2023 EDS file for an FLnet device? EDS is typically DeviceNet or EtherNet/IP, not FLnet.
Olly_J Posted August 23, 2023 Author Report Posted August 23, 2023 Thanks for the responses. @FRANK RUIZ - I think you may be right, I probably just have to contact our Mitsubishi rep. @Crossbow - I am not sure what sort of file it is I need but whatever it is I need to open the .gx3 file that has that FLnet module in it. As it is I cannot even open the file. I am not that interested in the FLnet module in this case, rather the logic in the .gx3 file. I can open other .gx3 files that don't have that module it them.
GreenMan Posted August 24, 2023 Report Posted August 24, 2023 Hi To open the procjet you need to install the profile for the FL module. You can fin what you need here: https://us.mitsubishielectric.com/fa/en/search#q=ER-1FL2-T&sort=relevancy This web site have some problems with some files. Often the easyest fix is to use firefox to download. See chaper 4.5 for installation info Test from manual: In order to use FL-net module with GX Works3, installation of module profile, module label, module FB is necessary To open the file: .gx3 is a zip file, and bye changing the extention you can unzip it and take a look inside. 1
Olly_J Posted September 11, 2023 Author Report Posted September 11, 2023 @GreenMan Thanks for that. I didn't realize at first that you have to be logged in to the mitsubishi electric account to be able to see all of the search results. I was only seeing 2 PDF files before logging in and thought there was nothing useful to see but after logging in I was able to see the Zip file, and download and install the module. Now it works. Thanks for your help. 1
glavanov Posted September 13, 2023 Report Posted September 13, 2023 Here's the Net Profile files for GX Works3 and FB: https://us.mitsubishielectric.com/fa/en/support/technical-support/knowledge-base/getdocument/?docid=3E26SJWH3ZZR-37-1208 You might need registration...
