vanquangtk Posted August 24, 2023 Report Posted August 24, 2023 Hello everyone, I'm looking to use a timer with a 10ms interval in a function block. However, I'm unsure about how to create it, as all the timers I've declared so far are set to 100ms. Could someone please provide assistance? Thank you. Quote
Crossbow Posted August 24, 2023 Report Posted August 24, 2023 It would really help if you indicate which family of PLC you are using, as there are some differences. Quote
vanquangtk Posted August 24, 2023 Author Report Posted August 24, 2023 6 minutes ago, Crossbow said: It would really help if you indicate which family of PLC you are using, as there are some differences. I use FX3U PLC. Quote
nehpets Posted August 24, 2023 Report Posted August 24, 2023 The time base is dependant on the timer number, 2 Quote
vanquangtk Posted August 25, 2023 Author Report Posted August 25, 2023 19 hours ago, nehpets said: The time base is dependant on the timer number, Thanks, but I want to create a TIMER_VAR not a fix address timer. Quote
Crossbow Posted August 28, 2023 Report Posted August 28, 2023 Not sure you can do what you ask in FX3U. Look at the options in the software to determine what addresses are reserved for variables created without an address, then look at the info that nehpets shared so you know where it will wind up when you do not specify an address. 1 Quote
