I am attempting to use the word lamp functional object to display 4 different colors depending on the INT value of the display address. The "Queue" column 1-10 has a "Display & Input" overlapping each "Word Lamp". When I attempt to customize the word lamp under the "Color/Shape" tab, I am prompted 10 possible colors with 10 different values. My display address INT value can be between 0-90.
64fb6effc0597_Screenshot2023-09-08145845
Edited by Glenn Campbell
Unnecessary Screenshot was accidently added
What are your 4 color INT values? Is this the issue? You don't really state a question.
If 0 through 9 are not options for you, you may use Indirect reference where you can choose 00 - FF Hex (0 - 255 Decimal).
