seroke Posted September 25, 2023 Report Posted September 25, 2023 Hi all , I'm new on Mitsubishi , so i've some problems. I need to write an endless timer. *I have to use just 1 timer. *If click start; -1s later 1st lamp -2s later 2nd lamp (together) -3s later 3st lamp (together) -4s later 4th lamp will be on. -5s later they will be off. -6s later it will start again from first step. Please help me... Quote
pturmel Posted September 25, 2023 Report Posted September 25, 2023 Sounds like a classroom assignment? 2 Quote
Ron_S Posted September 26, 2023 Report Posted September 26, 2023 Show us how far you have got and we will gladly assist you. A tip: If timer = 1 then ? 1 Quote
seroke Posted September 27, 2023 Author Report Posted September 27, 2023 22 hours ago, Ron_S said: Show us how far you have got and we will gladly assist you. A tip: If timer = 1 then ? if timer = 1 ..start lamp1 timer = 2 ..start lamp2 timer = 3 ..start lamp3 timer = 4 ..start lamp4 timer = 5 ..reset all.. .this part works. but it should restart and be endless.. Quote
DaMro Posted September 27, 2023 Report Posted September 27, 2023 try to put timer NC contacts just before timer. So when timer reach 5 sec. it will reset by itself, and starts to count again 1 Quote
Yuto24 Posted September 27, 2023 Report Posted September 27, 2023 Also you can use a coil when the 5th timer is activated to have an interlock to m25 an reset the sequence, then an NC to cut the energy of the ladder 1 Quote
