Good morning friends
I need clarification, for which I leave a copy of the program under test, as I need to understand what is going on with this problem.
In the test program that I leave you, every time I change the d10 to 500 pulses, the rise and fall do not stabilize as for example with 400 pulses or 300 pulses. Can anyone help me understand what's going on with this???
Thank you very much in advance for any and all help you can give.
Rui Silva
simulador de movimento dos mandrins.cxp
The counter is counting in BCD. You are comparing it to a Decimal number.
The CJ1 doesn't not have a Decimal counter so try counting up and down using + and - instructions.
  • Like 2
