WattUp Posted November 16, 2023 Report Posted November 16, 2023 4 hours ago, madhan said: No it is not working I have seen a post that says if we remove the CPU battery and power it down for a day then it will go it is factory state even tried this method but no Luck just asking is there any firmware update or procedure do a full factory reset for this CPU I dont have spare CPU better go for service I think How about an ethernet card, do you have a spare QJ71E71-100 laying around?
madhan Posted November 23, 2023 Author Report Posted November 23, 2023 I dont have a ethernet card thinking of buying a used one meanwhile i would like to communicate my weintek HMI to this model CPU using Modbus QJ71MB91 can someone Provide me the process to communicate Thank you
WattUp Posted November 27, 2023 Report Posted November 27, 2023 I have not used that HMI brand before, but Modbus setup on the MB91 is pretty easy. It will show up as an intelligent function module and have several setting windows. Switch settings is for IP setup and pointing device assignment to the user settings Modbus device assignment tab will be how you set up blocks of addresses to be shared by the HMI and PLC
madhan Posted December 1, 2023 Author Report Posted December 1, 2023 no this model is a serial communication model and the switch settings for plc and HMI are same, used rs485 cable connection and I dont know why I need to set device assignment for HMI. Is there any specific procedure for HMI and PLC (any HMI not only this ) through modbus communicaiton ?
