Hi,
I write a CAM function to sync 2 axis (Rotary & linear).
i am using a virtual servo as master, and 2 physical servos as slave. The problem i facing is, with the exact same CAM profile setting, when difference speed used will give difference result of movement.
Below is my setting,
Master axis     linear motor move
0-180degree   0-500mm
180-360          500-0
when running with slow speed, it move following the CAM profile setting, however, when moving in fast speed, the linear motor will only move halfway then start to moving back 0 already.
Has anyone encounter this issue before? is it i missed out some setting?
Thanks.
