ABlearner Posted November 7, 2023 Report Posted November 7, 2023 Hello Guys. Is it possible to use an fr-a840 to use in the same time positioning control and also in speed control mode ? In the moment the vfd is in speed control mode. But now i also have to need to stop the conveyor in certain position. It will be a new feature. If its not possible, do i need a hsc ? The speed of the conveyor is 20 m/min and the accuracy should be within 3 mm. Could anybody help me with this. Thanks ahead.
glavanov Posted November 7, 2023 Report Posted November 7, 2023 Section 5.5 from here: https://dl.mitsubishielectric.com/dl/fa/document/manual/inv/ib0600503eng/ib0600503engm.pdf But a lot depends on the equipment you have available... What PLC? Is there positionnig card installed on the A840 and motor feedback (encoder)?
