IO_Rack Posted December 2, 2023 Report Posted December 2, 2023 From a PM: On 11/30/2023 at 11:07 AM, abbas49326 said: Hello, don't worry, I have an HMI device with the same problem. Please give me the download link to build RAM and fix the problem. Thanks All the files and instructions are contained within CX Designer program installation. The hard part is finding a CF card that will work with this operation. Note, any CF card formatted in Windows of any version will render the CF card useless in an NS screen. Your best bet is to purchase one from Omron and never, ever, ever format it. The format needs to be FAT16. Any version of Windows can do this but it doesn't work. I've tried formatting in several different programs, devices and even an Omron PLC but it still does not work. If anyone has uncovered this mystery, please share. Quote
pturmel Posted December 2, 2023 Report Posted December 2, 2023 Pretty sure Linux could format it with FAT16. Or take an image of a good one to write back to a device in a crisis. 1 Quote
S1090 Posted December 3, 2023 Report Posted December 3, 2023 11 hours ago, pturmel said: Pretty sure Linux could format it with FAT16. Or take an image of a good one to write back to a device in a crisis. I already tried in ubuntu with kde Partition manager, but it not works. Quote
pturmel Posted December 3, 2023 Report Posted December 3, 2023 2 hours ago, S1090 said: tried in ubuntu with kde Partition manager I wouldn't expect a gui to work. This is something you need the precision of the command line for. Look at the manpage for mkfs.fat. Quote
S1090 Posted December 5, 2023 Report Posted December 5, 2023 On 03/12/2023 at 10:50 AM, pturmel said: I wouldn't expect a gui to work. This is something you need the precision of the command line for. Look at the manpage for mkfs.fat. Formatted CF card with mkfs.fat in fat 16 through ubuntu terminal ...but same problem PT screen remain blank ...no response. Quote
chelton Posted December 5, 2023 Report Posted December 5, 2023 1 hour ago, S1090 said: Formatted CF card with mkfs.fat in fat 16 through ubuntu terminal ...but same problem PT screen remain blank ...no response. Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb Quote
S1090 Posted December 5, 2023 Report Posted December 5, 2023 (edited) 4 hours ago, chelton said: 4 hours ago, chelton said: Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb Tried creating partition with sudo cfdisk /dev/sdd But MBR is not listed here , only GPT and Dos. On 03/12/2023 at 10:50 AM, pturmel said: Edited December 5, 2023 by S1090 Quote
S1090 Posted December 5, 2023 Report Posted December 5, 2023 8 hours ago, chelton said: Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb I am not familiar with ubuntu and terminal commands ..need help to resolve it 8 hours ago, chelton said: Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb 8 hours ago, chelton said: Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb Tried creating partition with sudo cfdisk /dev/sdd But MBR is not listed here , only GPT and Dos. On 03/12/2023 at 10:50 AM, pturmel said: Quote
photovoltaic Posted December 5, 2023 Report Posted December 5, 2023 In Windows I used a generic 1GB CF card. I used the Windows Disk Management utility. 1) Delete the volume 2) Create a new volume (size 64MB, FAT, Default Allocation, Quick Format) 3) Transfer Restore Files and recover the screen Quote
S1090 Posted December 8, 2023 Report Posted December 8, 2023 On 05/12/2023 at 9:07 PM, photovoltaic said: In Windows I used a generic 1GB CF card. I used the Windows Disk Management utility. 1) Delete the volume 2) Create a new volume (size 64MB, FAT, Default Allocation, Quick Format) 3) Transfer Restore Files and recover the screen Tried same method with 2 CF cards one is 128 mb and 2nd 1 gb. But Response is same of PT. Light get Green but screen remains black. Is there any special requirement for internal CF (ROM) Card which i had changed earlier, i bought new CF card (128 MB) and just installed internal side of PT. Is there problem in CX ONE's versio?. Is recovery Update 8.95 is compatible for NS12-v2 ? On 05/12/2023 at 11:49 AM, chelton said: Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb I am not familiar with ubuntu and terminal commands ..need help to resolve it On 05/12/2023 at 11:49 AM, chelton said: Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb On 05/12/2023 at 11:49 AM, chelton said: Just tested an old CF card and formatted with linux. It certainly does work. Are you copying the files to the root directory on the CF card? Clear any partitions on the CF and create a new empty MBR partition table. Then format to fat16 -> ie sudo mkfs.msdos -F 16 /dev/sdb Tried creating partition with sudo cfdisk /dev/sdd But MBR is not listed here , only GPT and Dos. On 03/12/2023 at 10:50 AM, pturmel said: Quote
photovoltaic Posted December 8, 2023 Report Posted December 8, 2023 Quote Is there any special requirement for internal CF (ROM) Card which i had changed earlier, i bought new CF card (128 MB) and just installed internal side of PT. I believe the special requirement is you never touch the internal CF card. If I get a chance today I'll see what mine contains. Quote
photovoltaic Posted December 8, 2023 Report Posted December 8, 2023 9 minutes ago, photovoltaic said: I believe the special requirement is you never touch the internal CF card. If I get a chance today I'll see what mine contains. Its an unrecognized file system on the internal CF. If you formatted yours I think that's the end of your screen Quote
pturmel Posted December 8, 2023 Report Posted December 8, 2023 2 minutes ago, photovoltaic said: unrecognized file system On Windows? Even if unrecognized on Linux, a sector copy can yield a "blank" usable to recover the original behavior. Quote
photovoltaic Posted December 8, 2023 Report Posted December 8, 2023 10 minutes ago, pturmel said: On Windows? Even if unrecognized on Linux, a sector copy can yield a "blank" usable to recover the original behavior. Yes, checked on Windows. It is split into 2 partitions and Windows can't tell what filesystem they are. Perhaps one contains a bootloader, the other the OS. Quote
chelton Posted December 8, 2023 Report Posted December 8, 2023 9 hours ago, S1090 said: Is there problem in CX ONE's versio?. Is recovery Update 8.95 is compatible for NS12-v2 ? I've been unable to get version 8.95 to restore correctly on NS10-V2 screens, however it works fine on NS5. The screens lock up at "copying system files" and the indicator light either stays solid red or off. Version 8.6 is the latest version that i can get to restore correctly on these screens. Quote
S1090 Posted December 12, 2023 Report Posted December 12, 2023 On 12/8/2023 at 9:57 PM, photovoltaic said: I believe the special requirement is you never touch the internal CF card. If I get a chance today I'll see what mine contains. it is a big mistake by my side that i formatted internal card, is there no any chance to recover this NS12??? Quote
S1090 Posted December 12, 2023 Report Posted December 12, 2023 On 12/8/2023 at 1:47 AM, chelton said: I've been unable to get version 8.95 to restore correctly on NS10-V2 screens, however it works fine on NS5. The screens lock up at "copying system files" and the indicator light either stays solid red or off. Version 8.6 is the latest version that i can get to restore correctly on these screens. can you please send me 8.6 version ??? Quote
IO_Rack Posted December 12, 2023 Author Report Posted December 12, 2023 (edited) HMI Sample Code - Forums.MrPLC.com There are several older versions here at Mr PLC. I checked downloads section at Omron's website and they only have the latest (8.95). I don't know how we could download select versions. It's probably not possible since the NS is obsolete. If you require a different version you could contact Omron tech support. They may be able to supply them without liability. I know there are some Omron guys on these forums but I haven't seen them in a while. Edited December 12, 2023 by IO_Rack Quote
IO_Rack Posted December 12, 2023 Author Report Posted December 12, 2023 I'm confused as to the problem you are having now. Are you able to format and install files to the card? Or having the NS lockup issue when installing to the screen? Quote
chelton Posted December 12, 2023 Report Posted December 12, 2023 On 08/12/2023 at 7:17 AM, chelton said: I've been unable to get version 8.95 to restore correctly on NS10-V2 screens, however it works fine on NS5. The screens lock up at "copying system files" and the indicator light either stays solid red or off. Version 8.6 is the latest version that i can get to restore correctly on these screens. Just to update -- my CF card was defective, i formatted a new card and could get 8.95 to update correctly. Quote
chelton Posted December 12, 2023 Report Posted December 12, 2023 9 minutes ago, IO_Rack said: I checked downloads section at Omron's website and they only have the latest (8.95). MyOmron>Downloads>Products>HMI>NS Firmware has all the firmware dowloads. 1 Quote
chelton Posted December 12, 2023 Report Posted December 12, 2023 4 hours ago, S1090 said: it is a big mistake by my side that i formatted internal card, is there no any chance to recover this NS12??? Any chance you have another NS screen that you can clone the CF card? Linux "dd" command could do a byte for byte copy of a working internal CF card. 1 Quote
S1090 Posted December 13, 2023 Report Posted December 13, 2023 19 hours ago, chelton said: Any chance you have another NS screen that you can clone the CF card? Linux "dd" command could do a byte for byte copy of a working internal CF card. NO i had only 1 screen. Quote
