PaulKim1003 Posted December 19, 2023 Report Posted December 19, 2023 (edited) Hi, I created a tag(paul) as dint. I have paul.%x0 and paul.%x1 and I can not modify them (to make them on/off) is it possible to enter a value into the monitor value? if possible, I would like to put 3 into the monitor value to make the paul bits ON. Edited December 19, 2023 by PaulKim1003 Quote
Hati Posted December 20, 2023 Report Posted December 20, 2023 Depends what version of TIA you are using. From v16 -> you can just double click on the monitor value and it opens a box where you can change the value. You can also use the VAT table to write the individual bits of the tag. Quote
