Hi all
Currently having a communication issue between ns runtime and CP2E. I can ping both the PLC and computer the ns runtime will be installed on and i can ping the PLC from the computer with ns runtime. However when i load up ns runtime i get the timeout error. I believe it must be a setting on my part as i get the same issue when i try to run the simulator. See below for my set up. Hopefully it is something small i have missed. I also tried to use Fins with the same outcome.
Appreciate any help on this.
Image previewGetAttachmentThumbnail?id=AAMkADViMGI4YjGetAttachmentThumbnail?id=AAMkADViMGI4Yj
Not sure if its a problem my end but can't see any images on your post.
Hi Chelton
No i have just checked think its my fault will try to re-add them. I have attached this time instead
