Have a plc relaying logic to the Mitsubishi plc and the logic reads [ TO        D7000        K1148        K4M4000        K2        ]
Curios how to read this logic.  Only found information on k4m4000 is that k4 controls 16 bits past m4000.
Thats right evevery K is 4 points
In this case M4000 -M4015 is written to buffer memory 1148 of the speclal module on location D7000.
As there is K2 in the End this means the following BFM1149 is also written to with M4016-M4031
D7000 should contain a I/O nr of the module.
Edited by Gambit
  • Like 3
