Bryll Posted February 12, 2024 Report Posted February 12, 2024 I need to use a S7 1214 PLC and connect to two different IP-addresses. The PLC will be connected to three other 1200 systems on "network 1" collecting data on a Profinet "machine network". Customers DCS is collecting data from the 1214 PLC via Modbus TCP on a separate IP-address. Can I use a CP 1243-1 communication module for the second network or is there a better one? Regards /peter Quote
