Geir Posted March 15, 2024 Report Posted March 15, 2024 Lately I have been having a struggle importing tags into JMobile from a CJ2M CPU31, I can enter tags directly and it works OK, but when I try to import tags nothing works, there are the yellow triangles on all the widgets. I tried to import using the "normal" Ethernet protocol by first making a .CXR file from the global symbol list, it seems to create the dictionary, and I can update the taglist and the tags appear to have the correct datatype and address, but no joy. I also tried the EthernetIP protocol by making a cjf file, funny thing is that worked for a while, but stopped communicating after a while. I have successfully used the EthernetIP import on anotherĀ CJ2M/Exor eSmart. Any way of troubleshooting this, adding 50+ tags by hand is not very tempting :( Geir Quote
