pjw Posted March 19, 2024 Report Posted March 19, 2024 Hi, I appreciate any help to understand how to change ip in my FX3U mitshubishi plc. I can connect to it via default address but can't change it. If I try to do it by GX Works2 to i get info that "Connected PLC is attempting to write an unsupported data. Please check the PLC version". I mean when I try to set in project window by Parameter>>PLC Parameter>>Ethernet Port (i can fill this window and save it in program, but when I try to write it to plc, then get message above) But in GX Developer i even can't set anything as this window for network parameters is missing. Paramter>>PLC Parameter (there is no window for network settings) Quote
colandra Posted March 19, 2024 Report Posted March 19, 2024 Are you using a FX3U-Enet module. If you are there is a configuration tool you need to change it in the module directly. I have attached it, this may help. Colandra FX+Configurator-EN+1.40.zip 1 Quote
Goghie Posted March 19, 2024 Report Posted March 19, 2024 It may be also directly programmed in PLC application. Quote
pjw Posted March 20, 2024 Author Report Posted March 20, 2024 colandra thank you for the tool ;), will try it now Goran, I did not get any chance to change it, I did try by GX Developer and GX Works2 Quote
