how to write D register value into M memory address?
Hi,
Is there any way to write value from D registers into M memory address?
I would like to read analog value of my AI and send them to WinCC Flexible,
there foud a way to use Modbus TCP IP to send data, or COM, but in both ways I can only read M, MV, I or IW address
in WinCC Flexible.
I did try with MOV function to copy D register data to M, but it is not working in GX Works2
Edited by pjw
D0-K4M0.thumb.jpg.ef08902cf137b08a92991f
I'm a bit rusty with WinCC, but you should be able to just add the data register as a tag in WinCC and associate it with a numeric value in the HMI program
Edited by glavanov
