i am connecting single GOT2000 to two diffent PLC.   i.e R16 inbuilt port and Qj71en71 card. communication Done. but GOT become slow. sm412 blinking stops inbetween. What is the proble for slow comm.
Did you use different stationnumbers for the connections ?
Do you communicate large amounts of data  ?
What is the scan time of the PLC's ?
Did you use different stationnumbers for the connections ? -------> YES ( different stn no's  including PLC and other GOT's + kept NW no. same.
Do you communicate large amounts of data  ? -------> YES
What is the scan time of the PLC's ? -------> Max scan 190ms ,Current scan 69ms ,min scan 38ms
total connected GOT's are 20 no's
After increasing 10% to 50% speed got improved bit. Thank you so much Gambit for that. but i had to devide GOT's with another Ethernet port. All GOTs were connected barcode scanner so i wanted high speed scanning. notification and control devices were getting on and off slowely. in 6 time scanning i used get 3 times only.
