Hi,
I'm thinking about using commands for Melservo J5 controller via HMI without PLC.
Have you guys done this kind of control configuration for Melservo?
if anyone knows or familiar of this, please share our knowledge like communication methods, command methods (start, stop, alarm, and so on)
Thanks,
Mark,
I do not have any preference for the protocol spec for the device.
What kind of protocol options can I have for the J5 controller?
Controller unit will be MR-J5-70A so far, and I'm looking for communication options for HMI without PLC connection
I do not know. But, if you find one or more send it to me and  I will read it.
For the Mitsubishi Electric GOT HMI there is a complete sample available in de GT Designer3 software to connect the GOT2000 to the MR-J4-A (-RJ)
The connection is running via the RS485.
For example you can use the build in point table of the drive, change them via de GOT and run the set positions from the HMI.
Sample projects can be found in the GTD3 software, Project > Utilize Data, select Sample Project, Search for J4
  • Like 1
