Converting NS screen to NB5 screen
Hi all
Have done some very basic checks and believe that there is no straight forward conversion for this and that it would need a re-write in NB5.
Other than going directly to Omron is there any freelance alternatives, UK based, that can be recommended.
Thanks
NS screens can be converted to NA5 screens (a rough conversion). If it's a large HMI project that might be a quicker and cheaper route to go.
If you need to stick with the NB most integrators should be able to do this conversion for you.
You can also use a piece of software called NS Runtime and run the NS application on a PC.
Hi There
Thanks for the reply and info.
