I made an Ethernet connection between an NX1P2 and a CJ2M using network configurator and I already have a real-time data input and output connection in the memory of both plcs. I need to send a 20-byte word and when the NX1P2 is modified in the CJ2M using Sysmac Studio, it receives that string of bits, decompresses each bit to be able to activate the NX1P2 outputs.
