Hello,
I seek some help white something new for me.
I wanne use a encoder the contorle the speed of a conveyor band. Because the weight on the conveyor band is not always the same.
I all ready use the encoder puls to position the conveyor band. But I also whanne use this for speed contorle. can somewanne tell
How I can do this the best.
Basic info.
PLC = FX5U
Encoder = on X0 and X1.
Analoge speed to FRQ = plc anloge on board 0-10 volt.
FRQ  speed =  around the 35 HZ.  = 6 volt from the plc
How can I make this happend?
Hey AJ.
In the FX5 high speed counter settings you can select Rotation speeds measurement.
This will give you a speed/rotation value.
However a good drive would keep the correct speed even with different loads on the conveyer.
Whcih drive are you using ?
  • Like 1
