PiglesanI Posted June 2, 2024 Report Posted June 2, 2024 (edited) Hello.We have a broken power module MDX60A0750-503-4-00 SACH NR 8226644NR 0235016F 0..180HZ on a control unit MDV60A0750-503-4-00.We put a new power module MDX60A0750-503-4-00P# 08226644S# 31.6181737301.0002.24F 0...599HZ butWhen we power on we get an almost instant F01 overcurrent fault.The new power module came with a MDX61B control unit.Is there something we can do to make it work the new power module with the old control unit.The power module are almost the same except the frequency output.Thankyou. Edited June 2, 2024 by PiglesanI Photo remove Quote
