zubair136 Posted August 2, 2024 Report Posted August 2, 2024 Dear All, i have S7-1200 with seimens hmi. Problem is that Siemens Hmi is Far Old and now touch is problem . So In replace Weintek Hmi is selected. -----the problem i am facing the data block is optimized in program so i can not access tags in the weintek Hmi. if i remove the optimization option in attribute then further i could not select some values are retain and some are not. ---- Kinldy suggest me how can i access in weintek the with optimization property check or if you have any other solution Regards, Zubair Ahmed Quote
Moggie Posted August 5, 2024 Report Posted August 5, 2024 Have you looked at this ? - https://dl.weintek.com/public/MT8000/eng/FAQ/FAQ_77_Establish_iSeries_S7-1200V4.0_Communication_en.pdf Quote
Hati Posted December 25, 2024 Report Posted December 25, 2024 You can't access optimized DB's with Weintek. Those only work inside the Siemens ecosystem. Quote
