Hi
When I copy and paste in the gx works2 program, it adds the pasted command below or above, I cannot place it where I want to add it. And when I try to draw a line with ctrl, it shifts where the line goes. (win11)
Thanks
What exactly you are pasting and where? Some instruction must be in certain place and required exact amount of room in the rung. And when you online edit of the rung, you are limited in the amount of rung you can work with above and below and amount on rungs you can paste in the time.
As you can see in the image, this is what happens when you copy and paste. But not on all pages, only on some pages. It may be related to the Windows version
  • Like 1
That is what Ron_s said. See your outline of the contact is purple. If you insert in that mode it will add a line. Press Inc. ones and it will turn to normal blue outline which will paste/overwrite the cell.
Edited by SergeyBorchshev
  • Like 2
