FX5U initial output states are unpredictable.
I am using Fx5U PLC. Is there any way to setup the initial state of the PLC outputs when the power is restored (OFF to ON)?
Currently it is not consistent. I mean some outputs may be triggered if the power is restored by a disconnect. I have to press reset to solve this problem each time.
Hello HZ,
By default the FX5U should power on with the outputs OFF.
If you want to maintain Y outputs, you could look at integrating SM402 (first scan) or SM8033 (memory hold function) into your logic.
If you are using a different output type or a module, please include those details.  Hope this helps!
  • Like 1
