robror_ Posted September 10, 2024 Report Posted September 10, 2024 Hi there! I'm trying to communicate a S7-1500 CPU via Modbus TCP with an CJ2 PLC using a CP1W-MODTC61 card. I configurated the MB_Client and the CP1W-MODTC61 was also configured as the attached files show. The thing is that I could not read any data from the PLC (the registers are in the correct address and memory area) and I tried different combinations until I started to get data (with the correct values) for a moment, even with a configuration I already tried. After that the block kept writing a 8200 error in the status word and no data was received. According to the manual that reads: A different Modbus request is currently being processed via the port. Another instance of MB_CLIENT with the same connection parameters is processing an existing Modbus request. I can confirm that there is no other device doing a Modbus request in either the 1500 or the CJ2, and I only have one MB_CLIENT block in the entire program. So that's where my question comes, is the CPU detecting another "ghost" request, even if there shouldn't be any? Or am I missing something in the CONNECT structure of the block? Thanks in advance for your support! Click to choose files Quote
Moggie Posted September 14, 2024 Report Posted September 14, 2024 Try putting a normally closed of "BUSY" in series with "M0.7" in the "REQ" input Quote
Hati Posted December 25, 2024 Report Posted December 25, 2024 On 9/14/2024 at 10:24 AM, Moggie said: Try putting a normally closed of "BUSY" in series with "M0.7" in the "REQ" input Yeah, using a clock bit for the REQ is a bad idea. You need to evaluate the status of the block for the REQ activation. BUSY, DONE and ERROR evaluation needs to be the conditions for the REQ activation. Quote
