I have to control a flow valve, for a hydraulic regulating valve. I have a stepper motor, 1.8* step, regulating valve 0-270* opening.  I m pulsing the stepper motor driver for CW/CCW.  My issue is i set the valve to open from 0 to 50* , 30 on my hmi screen. This requires reducing, so i enter 25, My only means of measurement is counting the pulses immitted from the PLC.  I have the Original 30 input, i now need to move reverse 5 pulses, and this may need increasing /decreasing to find the correct flow of pressure. This is operating a band saw in a foundry, and it limits the lowering of the blade while cutting,
