 Hi all
    Just a few words about me. I am Nikolas or Nik. I am electrical engineer mostly in industry. My knowledge in automation is enough to excecute my duties as maintenace engineer. I can reed ladder and also i am able of microcontrollers programming only in c. During my 35 years of working in that sector i made some automation projects at work medium size but never were involving HDMI!! The truth is i like these things a lot and i am not afraid to try new things and get knolidge even at that age. Now lets go to my question.
   I am building a house and i want to use automated systems.The general idea in the first stage, is to use master plc in the house with an HMI wall mounted in the entrance and connection in a private hub for using also an ipad as remote control in the house. This master will have 2 slaves. One for handling all the outside area and automated doors as the heating system from the garage building with a local HMI, the other will controll the swimming pool.
  So get them all together can you advice a PLC that can have communication with wifi,other microcontroller boards(arduino or pic) and other PLC's with affordable price.
Any PLC can communicate with Wifi if it has an Ethernet port and you have a wireless access point.  One PLC with multiple HMIs may do what you need.  Unless you want local I/O at each location.  I've done automation for 26 years, and I have done some around my house.  I did not build a house, so didn't get to do exactly what I was after.
Not sure where your comment about HDMI fits into this...  PLCs don't use HDMI...
