Display HMI content on monitor or TV
Go to solution Solved by Sleepy Wombat,
Is there an easy way to display the contents of my HMI (Omron NS8 or Weintek HMI) on a large TV.
TV will have HDMI and monitor input.
PLC is Omron CJ2M-CPU31.
If possible I would like to avoid the use of a PC, just copy the contents of my HMI to a TV.
Did you look at the specs of the NS8 ? a quick google and you will find NS-C001 and NS-C002 video output cards for the screens. Never used one. but worth a follow up on your end.
Thank you Sleepy Wombat.
After a quick look these units a re video input units.
I'm looking to go the other direction, display my screen contents on a large monitor or TV.
Rene
  • Solution
My Bad, regards the NScreen... then I would prob look at the Weintek HMI, in my opinion way more advanced for remote monitoring / access then Omron has available. You can VNC them, or via cloud app. Worse case scenario would be to use a NUC with VNC then display off that. And they are very competitively priced screen, bang for buck so to speak... 😉
Yes, I sure do like Weintek pricing compared to Omron screens.
weincloud sounds like a good option.
Probably get a mini pc of a tablet to connect to Weincloud.
Rene
After some more research I found out the Weintek mTV-100 is designed for this.
It links to your HMI and creates a HDMI output for your TV/monitor.
I will quote my project with the mTV-100 and keep you up-to-dateif the customer want to go for this option.
Rene
