Normally if you set a controller to be a slave in Profibus, you need to create the GSD within that controllers programming software. But since Omron doesn't have native Profibus support, i'm guessing that your PLC has a Profibus addon module. Check Omron website for a GSD's to the Profibus module. It's always the Profibus devices manufacturer who creates the GSD setup files.
8 hours ago, GERRYJJERESANO said:
I use CP1W -  CIF011 for my PLC
CP1W-CIF011 is a RS232 module
CP1W-CIF11 is a RS422/485 module
Going through the manuals, that module doesn't support Profibus, so you can't use it to build a Profibus communication.
